View Single Post
Old 07-30-2008, 05:07 AM   #9 (permalink)
Commando
Senior Member
Commando's Avatar
The block should be fine, but I will check it out, I assume there is less coolant from it getting so hot and turning into steam, and some how new coolant isn't going back into the engine. Thanks for the heads up, but a rag over the cap when I opened it, so no burns this time.
Will also check out the circuit, there has been a suspect wire on the outside of the choke that is loose as well, its come off a few times but never really seemed to make any difference.
Commando is offline   Reply With Quote
