View Single Post
Old 03-08-2007, 07:55 PM   #4 (permalink)
Ramrod84'
Junior Member
Location: Waterford, Ohio. Currently living in Washington DC
If you haven't got it fixed already, look closely at the battery conn. Having worked at Chrysler dealers for a little over 9 years i can tell you i have seen this more than once. Most of the time what happens is, because of the batt. location, they were prone to severe corrosion causing bad conn.at batt. and also corroding into the batt. cables. This may or may not be the issue, but its very common umung the later LH bodies. Keep me posted!
Ramrod84' is offline   Reply With Quote
