Bent Push Rods
Old Jul 29, 2008 | 07:39 PM
Bent Push Rods
BENT PUSH RODS
Hi, I have a 1967 Plymouth GTX 440. The engine is completely stock except for headers and a cam. I am having trouble with it lately. The push rods on one valve keep bending. There was a ticking sound coming from the rocker, and now that just stopped. When we put the new push rod in, we noticed the the engine was banging on one side. Once the lifter filled with oil again, the banging stopped. Then, I drove the car around the block. Came home, shut it off. A minute or so later, started the car, no oil pressure. This also happened last night on the highway near 5000 rpm, but we weren't doing that in the driveway. So, and help would be great.
Old Jul 30, 2008 | 04:10 AM
Commando's Avatar
Did you replace the lifters when you put the new cam in?
Old Jul 30, 2008 | 08:35 AM
I didn't replace the cam. When I got the car, I just had to put the heads and intake manifolds back on. I'm not sure what kind of cam it is, but it isn't an all-out racing one.
Old Jul 30, 2008 | 08:37 AM
But I also put new lifters in when I did all of this.
Old Jul 30, 2008 | 09:48 AM
Commando's Avatar
Ok, I know a lot of issues can occur with the lifters if they are not replaced, especially if the lobes are bigger in the newer cam. The lifter could also be bad, might want to take it apart and check to see if its good.
Old Jul 30, 2008 | 10:23 AM
Thanks for your Reply.
That's probably what I'm am going ot do next. I really don't wanna replace the cam. It is a big job on this car.
Old Jul 30, 2008 | 11:18 AM
Commando's Avatar
Definitely if you have it in the car, I put one in my 440 a couple months ago, but I had it out of the car anyways.
Still out of the car for that matter, but I can't help myself breaking bolts and delaying the install.
Old Nov 6, 2008 | 04:33 PM
i already fixes the problem
it had to do twith the zinc being taken out of the oil
it causes the lifters to fail, and the cam
usedknobby
Apr 30, 2013 08:26 AM
willysman69
Jul 18, 2012 12:42 PM
deadkelly
Jan 4, 2010 02:06 PM
Cracocuda
Aug 10, 2009 07:06 PM
67 GTX
Jul 30, 2008 08:41 AM
