Compatabilty '84 W150 360-LA/A-727/208
Old Nov 9, 2010 | 05:05 PM
Minnesota Guy's Avatar
All the 360's were called LA 360...1971--1993....The best heads were around 1988-89 and newer I believe..(swirl types) I pulled my 360 from my 87 4x4 Dodge..Typical...they all have cast cranks and externally balanced...The main thing is they all had 8:1 pistons which with the dish in them were closer to 7:5 :1 ...Wake it up with some low cost flat top hyper utectics...and shave the heads .050-.060 on the pre swirl heads....run a Comp xe cam, headers and dual exhaust, thermoquad intake..carter avs or afb.......You will pick up torque and gas mileage....run 89-92 gas...I was getting 17-18 mpg..otherwise the engine is a pooch and their worst balanced motor....They went cheap building them. Speaking from direct experience...I eventually took mine out for a 440...same type of build...i still get 16mpg..and a boat load more low end torque..
Old Dec 4, 2011 | 05:16 PM
camarobabe20's Avatar
does snyone here know about the 727 auto tranny? I have a 85 727 that i want to put in my 74 Power wagon. Will it work????
Old Dec 4, 2011 | 09:26 PM
Is the replacement 4 wheel drive ?
79Friesen
Sep 7, 2011 07:54 PM
Minnesota Guy
Nov 27, 2010 05:17 AM
chalvata
Nov 29, 2009 02:42 AM
lonewolf273
Nov 19, 2008 06:56 PM
oldfartracer2
Jan 7, 2008 10:26 PM
