Headers in a Mopar 440
Old Aug 5, 2008 | 03:55 PM
Commando's Avatar
I have a question for anyone that has encountered this while installing headers. When I removed the manifold studs I noticed that all of the holes go into the water jacket, so that when I put the headers in the bolts will also go into the water jacket, so what do I need to do to seal the bolts?
I appreciate any feedback on this. -Thanks
Old Aug 5, 2008 | 05:59 PM
Commando's Avatar
Use it like lock-tite, or put it on the end of the bolt and hope that it seals?
Old Aug 6, 2008 | 04:06 AM
Commando's Avatar
I have not put them in yet, but I assumed that the studs I pulled out were sealed well. Also I have not dealt with the holes going into the water jackets before, so I want to proceed with caution just in case there is a problem that could occur.
Old Aug 6, 2008 | 04:44 PM
Commando's Avatar
Ok thats sounds good, thanks for the help.
Old Aug 7, 2008 | 04:06 AM
Commando's Avatar
When I pulled the studs out they were all corroded and rusty on the ends. I asked another friend of mine about what he does in these situations, and he said he uses Boiler putty, have you ever heard of that?
Old Aug 7, 2008 | 02:33 PM
Commando's Avatar
My mechanic recommended that, been working on Mopars since the 60's. I only asked him yesterday, also he said that the rtv may melt and go into the coolant, have you done this before?
Old Aug 7, 2008 | 04:40 PM
Commando's Avatar
Whats the temp rating on the quality you would use for that? I melted through high temp spark plug wires with these headers, had to get those real high temp sleeves put on the wires to prevent melting, so I am always leery of products that do not have specific temperature ratings or are under 1200-1500 degree.
Old Aug 7, 2008 | 07:42 PM
challenger's Avatar
Hey Commando i would recomend using the Loctite RTV 5920 Copper Silicone ,, it is non corrosive like diolectric grease and withstands temps 700 degrees and would put it on the threads about 1/8 of an inch above bottom / i use it all the time and never have leaks
Old Aug 8, 2008 | 04:06 AM
Commando's Avatar
Thats true Doc, it has the temperature of the coolant, and there is some space between it and where the exhaust ports are.
I will look into that Challenger, sounds like a good product. What do you mean by bottom, do you mean the end of the bolt?
Another reason I am being cautious, is that they all go into the water jacket, not just the end ones. (I may have said that already)
Old Nov 6, 2008 | 04:40 PM
Commando's Avatar
I grabbed a tube of the copper, not sure if I am going to need it now, as I am replacing the heads with some Edelbrock ones.
Old Nov 6, 2008 | 07:13 PM
challenger's Avatar
Hey C dont forget to use anti sieze anyways , always use it on bolts and nuts so they dont corode in aluminum ok
Old Nov 6, 2008 | 09:09 PM
Commando's Avatar
Anti seize? Like loc-tite, or do you mean something else? just if it is bolted into the aluminum, or passing through as well?
Old Nov 7, 2008 | 05:37 AM
BuckNeccid's Avatar
Anti seize is about the opposite of loctite. It tries to prevent the interaction of dissimilar metals that cause the quick, thick corrosion and almost impossible disassembly of parts. We use it a LOT on locomotives, and it do work. Even tho it's way more expensive, I'd use the copper based anti seize due to the prolonged hi temps, and the cost of your heads. Someone earlier asked about Bolier Putty. Basically the same thing as Oakum, plumber's putty, etc. It's a waxy type stuff that was used way back when and is good for a lot of things, but I dont think I would use it to seal threads going into a head.
Old Nov 7, 2008 | 01:48 PM
challenger's Avatar
Angry
hey C go up 8 post and remember what i said about the Loctite RTV 5920 and you can use it like antisieze or if you are going with the aluminum heads then you can just use regular antisieze ... you can get the gray stuff from your local hardware or if you know a cat dealer in your area get there copper based antisieze ( catterpillar as in dozers / loaders / graders and earthmovers )
Old Nov 8, 2008 | 04:49 AM
  #24
that copper based anit-seize is some really good stuff. we use it at work on some bolts. touch stuff, especially to clean off.
Old Nov 8, 2008 | 12:32 PM
  #25
challenger's Avatar
hey guys sorry about the mad smilie i didnt put it on there on my last answer i dont know how it got there hummm must be gremlins and 78 , the cat dealer used to give us that antisieze like crazy but even they are cutting back on things they give out as even a hat is hard to come by , boy this economy sucks but at least the gas prices were at 1.89 today and my diesel is 3.29 guess we are still using more diesel these days
Old Nov 9, 2008 | 07:49 PM
  #26
Commando's Avatar
Ok I will look into that, now that you mention hat I have been unable to find my Cat Hat, great quality nice fit, damnit. That all makes sense I will use it as that seems important.
Old Nov 10, 2008 | 02:10 PM
  #27
challenger's Avatar
you better find that hat C as like i said even they are hard to get
Old Nov 26, 2008 | 05:33 PM
  #28
Commando's Avatar
I got another question regarding these headers, has anyone every used fireplace paint on headers before? I think that it would be the best as I already paid 300 for paint that burned off.
Old Nov 27, 2008 | 05:06 AM
  #29
WOW!
I know of shops around me that will do ceramic coating for half that price. You should have gotten a high temp primer and paint in the rattle cans. As long as the headers were completely clean, the paint should have stuck.
I'm not sure about firplace paint but if you do, make sure that you clean off all the old paint. Sand blasting is a great way. Then clean them with mild soap and water.
Old Nov 27, 2008 | 06:49 AM
  #30
Commando's Avatar
They did a high heat ceramic coat, supposed to be 1700 deg, think it was only 1200. The paint came off in the obvious places, the tops of most pipes, and is now "protected" by rust. I will definitely hit them with a sand blaster, and wash them. The fireplace paint is the highest temp paint I have found, plus the high heat cures it, so I think if it can hold up in a fireplace which is much hotter then an engine it should be good.
