how to adjust vacuum advance
Old Jul 19, 2008 | 10:58 AM
gotdust's Avatar
i want to add some timing to my 73 360 duster with electric choke if it matters, how do i set it with vacuum advance, and what do i need to do it that way or can i just plug off vacuum at dist and do it there? i want about 38*. thanks
Old Aug 8, 2008 | 06:59 AM
ef8340's Avatar
Senior Member
Originally Posted by Doc
You should be able to do that through the vac hose hookup with an allen wrench. I have never done it .. but will be doing it for the first time on an RV project I have.
is there a allen head screw inside of the hose port on the vac adv module?
Old Aug 8, 2008 | 04:20 PM
ef8340's Avatar
Senior Member
id like to do this on mine how would you set it is there a spec chart ??? thxs again
Old Aug 10, 2008 | 12:14 PM
ef8340's Avatar
Senior Member
well i messed around with it and the hesitation is out of it but i havent takin it up the road yet need to get some trans fluid 1st seems that it leaked out some from sittin
Dodgecrank
Oct 15, 2013 10:23 AM
Hoff701
Apr 17, 2013 12:19 PM
SPICOLIE203
Dec 29, 2011 09:42 PM
nesparky
Jun 2, 2009 08:26 AM
68camperspecial
Apr 2, 2009 01:46 PM
