turboing the horizen
Old Aug 7, 2015 | 04:46 PM
85lebaront2's Avatar
The turbo engines are lower compression and the heads have better valves, same size, just better materials to take the heat. The turbo engines use 4 injectors, either under the manifold for 1984-87 T1, on top for 1988 up and all T2 engines. The SBEC (engine computer) for a TBI engine lacks the circuits for the wastegate control, second injector bank, sync signal and will not read the 2 bar MAP sensor correctly. The 1 bar MAP sensor is 5 volts at atmospheric pressure, the 2 bar is 2.5 volts at atmospheric pressure and 5 volts at 15 psi boost. The rods may be the same, and T1 engines didn't have a special crank, T2 and T3 are forged cranks, and T2 engines have floating wrist pins.
mark1818
Feb 16, 2012 07:54 PM
