intake problem
Old Aug 10, 2008 | 12:35 PM
intake problem
Anyone else here running a weiand action plus intake on their 318 or 360? do you have a problem with it sitting on the block? I got mine all bolted in and went to put coolant in and next thing I know I've got coolant pissing out of the driver's side front intake gasket area.
Old Aug 15, 2008 | 07:28 AM
Originally Posted by richinny
are there guide pins sticking up in the heads or the front or rear rails on the engine?
there are no guide pins.
Old Aug 15, 2008 | 07:30 AM
Originally Posted by Doc
Did you put any RTV around the coolant ports ? .... do you know the history on the intake?
i did not put RTV around the coolant ports. i never had to in the past but its probably something i should do on this. the intake is brand new that i bought from a shop that i've been dealing with for years.
Old Aug 15, 2008 | 10:34 AM
Do you know the history on the heads ? .....
The heads were replaced with the block as a long block assembly but a local engine shop about 6-7 years ago. they have not been milled.
Old Aug 15, 2008 | 10:36 AM
if the heads are milled, does the intake have to be milled to match the angles?
yes, if the heads are milled then the intake should be milled to match. i'm wondering if i need/should have the heads and intake milled to match. it would be a pain to deal with right now though.
rcknrolfender79
Mar 11, 2013 07:52 PM
kszysio
Mar 6, 2008 05:39 PM
