Swapping Tranny...
Old Aug 21, 2008 | 04:14 AM
Commando's Avatar
Hey Doc correct me if I am wrong but isn't the way the trans is balanced differently between the two. I think one is external and the other is internally balanced? Just something I heard while I was getting answers to my questions about my 400 and 440.
Also the converter isn't difficult to swap, you just have to unbolt it from the flexplate.
Old Aug 21, 2008 | 05:48 PM
Commando's Avatar
Oh ok, thanks Doc, I never looked too far into it as I bought the pair from the same car.
Old Aug 21, 2008 | 09:12 PM
challenger's Avatar
as far as i know you only have two tranny lines and they go to your radiator but as far as the third one i guess im lost as i have never seen a third one
Old Aug 22, 2008 | 04:06 AM
Commando's Avatar
Hey 71, are the three lines the same size? I can take a look at my setup in the car to see whats up with my 400 and 727, and do a quick look at the other trans for the 440 and let you know, but won't be able to look until later today.
Old Aug 22, 2008 | 10:26 AM
ef8340's Avatar
Senior Member
hey 71 im guessing yer kinda new at this did you make sure the converter was fully in before you mounted it(converter will make acouple of clicks as you turn and kinda lift up on the converter on the shaft then when attaching it to the the flex plate on the motor there will be a space inbetween the too but when you bolt it up it will pull together and still be okay and replaced the frt seal aint nothin worse than doin all that work then it leaks or dont even go asfar as the t. lines goe you should only have two you can take the lines that you have and splice them together in order to make trans lines that go to the rad. you'll need some compression fittings a pipe cutter and some sand paper 120 grit or alittle higher so that the fittings will seal get some line wrenches so you can tighten and loosen this stuff without damaging it kinda lost on the 3rd trans line unless you are refering to the speedo cable?
goodluck
cmetzbower
Oct 1, 2012 03:44 PM
Mudge1
Sep 15, 2012 08:44 AM
MoparMan76
Jan 9, 2011 09:43 PM
craveman
Apr 12, 2009 03:56 PM
bighammer
Apr 10, 2009 11:05 PM
