Stand alone wiring harness
Old 07-28-2010, 03:17 AM
Junior Member
mschoppe35's Avatar
I am installing a 1992 5.2L Magnum V8 into my 1975 Dodge Ramcharger. The engine is carburated at the moment but I picked up a 93' that I want to take all the injection stuff from and swap onto mine. The 93' block is toast by the way. I have read that carburated can produce more power but I'm looking at it at the angles of off roading that I frequently encounter. I am tired of flooding out a step angles.
I need a wiring harness that will run the engine only that I don't need to totally tie into my existing wiring harness. Possibly a place that can even re-flash the computer to get rid of sensors and stuff that I won't be using.
Thanks for any input that ay of you may have on this topic. Hopefully someone has done it in the past.
By the way I already contacted Painless. They don't do it and couldn't point me in any direction towards someone that might do it.
Old 07-28-2010, 04:32 AM
Crazy4Carz.Com's Avatar
Check MSD.
Old 07-30-2010, 05:55 PM
scotts74birds's Avatar
Check this system out. Its called Mega Squirt . Its a stand-alone FI system designed to use "off the shelf" parts to FI almost anything. http://www.megamanual.com/MSFAQ.htm#setup
mopartruck
02-23-2015 05:18 PM
h340
24
12-18-2014 09:19 AM
DeuceMan
04-29-2008 05:38 PM
dbaughman
04-05-2008 08:53 AM
Quick Reply: Stand alone wiring harness
