318 no start issue
Old Aug 22, 2008 | 10:42 AM
Monacoman's Avatar
318 no start issue
so since ive last posted about my 318 monaco with the bent/ broken rod i took the intake off to see about 7 of the rode were severely bent and the broken one lying on the valley so i tore the heads off cleaned everything replaced all the push rods put the whole motor back together changed the oil (made a huge mess on the drive way parents tried to kill me) and now she wont start i poured some gas in the carb nothing when i turn the key it sounds like the starter is the only thing turning the motor i replaced the plugs and wires and everything seems to be hooked up correctly, but she wont start any help would be much appreciated
Old Aug 22, 2008 | 11:44 AM
Commando's Avatar
What exactly did you pull off, did you do anything to the distributor, or mess with the timing? Perhaps missing a electrical connection or something.
Old Aug 22, 2008 | 12:26 PM
Monacoman's Avatar
i took off intake and heads didnt touch distri uter and had the car properly timed before i took it apart
Old Aug 22, 2008 | 05:46 PM
Monacoman's Avatar
139 000 just rebuilt the top end, ran before i took it apart but bad cause of push rods
Originally Posted by Doc
How many miles on the motor?
Old Aug 22, 2008 | 06:15 PM
ef8340's Avatar
Senior Member
are the plugs wet? are you getting spark to them? check the compression? right size push rods
Old Aug 22, 2008 | 06:25 PM
Monacoman's Avatar
i got spark put new plugs and wires got the exact push rods that came out of it getting fuel think possibly timing but no clue, when i turn the key nothing happens best way to put it the starter turns the motor over but thats it no ignition at all
Old Aug 22, 2008 | 06:43 PM
ef8340's Avatar
Senior Member
compression test? a motor only needs 4 things to run suck,squeeze,bam,and blow is it electronic ignition, or points? what color is the spark coming off of the plug should be whitish/blue =hot spark yellowish/orange weak spark why were the heads removed? has anything been done to them? do a compression test if your readings are low try squirting some motor oil in there to recoat the rings and bring the compression up
Old Aug 22, 2008 | 07:40 PM
Monacoman's Avatar
points and wouldn't it still run with low compression and this problem on all cylinders? i will try it tomorrow baught a compression tester today any other possibilities please let me know
Old Aug 23, 2008 | 05:34 AM
Monacoman's Avatar
to get to the timing chain? id dont think so
Like was said before ... the odds of you having cam timing issues are great. Are you capable of pulling the front cover off ?
Old Aug 24, 2008 | 01:09 PM
ef8340's Avatar
Senior Member
this is a dumb off the wall question but ill ask ne ways did u put a new set of head gaskets on it? you said before that the motor was running but poorly because of the bent pushrods and that you didnt remove the dist so the timing should not really be a factor in this problem unless something is wired wrong is there anything in the intake like a rag that might have been put in there after the carb was removed? was the fuel line filter put on the right way?are the rocker shafts tightened allowing the rockers to move up and down?
goodluck
Old Sep 8, 2008 | 08:43 AM
Monacoman's Avatar
k i dont hsave a timing light but can i really test it with out it being running, and to ef i replaced the gaskets i turned the engine with the rocker cover off the valves are opening and closing properly nothing in the intake and i too the fuell line off after the filter so its on straight its getting spark and has fuel also added fuel directly into the carb but wont catch just turns over cause the starter is turning it no ignition :S
Old Sep 8, 2008 | 03:51 PM
ef8340's Avatar
Senior Member
other possibilities
sounds like a weak spark,.......maybe?
remove a spark plug and crank it over while the plug is in the wire look at the color of the spark you want it to be a white/blue color yellow/red is not really a hot spark did you put back on the ground strap? or by any chance bump the dist while removing the intake or it could be compression when it was apart did you really go to town cleaning it up maybe with the cleaning you might have washed the oil away from the rings now this could give you serious blow by which in turn will not start the motor try alittle bit of squirts from a oil squirter with some 10w/40 motor oil in each cyl then crank it over acouple of times not trying to start it just to recoat to the cyl walls and rings this should bring compression back up im kinda at a loss without really looking at it but maybe some of these ideas may help
goodluck
Old Sep 9, 2008 | 04:09 PM
Monacoman's Avatar
spark is good just waiting for good weather to hook up my compression tester and see, cause not igniting at all so i might have the valves un adjusted i'll get back to you guys with the outcome and thanks again for all your help
Old Sep 22, 2008 | 06:22 AM
Monacoman's Avatar
hey everyone i got one prob fixed the vavles were off so no compression now it sounds like it wants to start but wont can smell gas from the exhaust, and good spark wonder if its just a matter of quickstarting the hell out of it as it was just put together??
Old Sep 22, 2008 | 04:10 PM
ef8340's Avatar
Senior Member
try alittle bit of squirts from a oil squirter with some 10w/40 motor oil in each cyl then crank it over acouple of times not trying to start it just to recoat to the cyl walls and rings this should bring compression back up you might have washed out the cylinders with all the gas going into it and not firing
Old Sep 23, 2008 | 12:39 PM
Monacoman's Avatar
SHE RUNS thanks for all your help basically first the compression was off then the timing now it runs and im gonna hook the timing light up but have no clue what it should be set at any ideas? i was gonna go with 0 :S
Old Sep 23, 2008 | 09:07 PM
challenger's Avatar
what year is it -and are you in california ? california has a different degree
Old Sep 24, 2008 | 05:57 AM
Monacoman's Avatar
the car is a 66 and im in canada toronto area
Old Sep 24, 2008 | 03:53 PM
  #24
ef8340's Avatar
Senior Member
i'd start with around 10btc and fine tune it from there, now mine seems to like that area of timing but every motor is diff
Old Sep 26, 2008 | 04:55 PM
  #25
challenger's Avatar
i do not have a manual for that year but like e says try starting out with 10 but it could be around 2 btdc if i remember right
Old Sep 26, 2008 | 04:58 PM
  #26
challenger's Avatar
hey rich that was a funny one haha
Old Sep 27, 2008 | 06:13 AM
  #27
Monacoman's Avatar
hey i set it to around 6 sounds nice but for some reason its started good when i hammer it now it chokes out when i hammer it then goes but runs smooth and doesn't shake on idle?? i hope to god its not another push rod
Old Sep 27, 2008 | 09:15 AM
  #29
Monacoman's Avatar
yes i did disconnect it when setting it there was no bog earlier but now its bad it started after a small back fire dont know what happen was running good then one back fire now it bogs
