LA Heads and Cam on a Magnum
Old Aug 23, 2008 | 12:44 PM
the best way to fix this problem and to sell the heads and cam and get a set for a magnum motor. I pretty sure there is no way, OR a really expensive way of fixing it but you;d be better off selling what you have and getting a set for a magnum.
Old Nov 30, 2011 | 01:21 PM
B5Dart69's Avatar
I'm having a similar problem. i have a 360 magnum with a 360 LA crank and internals. not sure if this set up is gonna work. im pretty sure the cam will work with your motor. the heads will not work. the magnum heads have different oiling ports and oil through the pushrods. if anyone else has any insite on this it would be much appreciated
Old Nov 30, 2011 | 04:21 PM
Since you already have the parts, Cheapest way would be to get a LA block as there are too many differences
Old Nov 30, 2011 | 04:46 PM
These two items should answer your questions:
http://www.allpar.com/mopar/LA-V8-en...ead-swaps.html
http://www.hughesengines.com/TechArt...numheadsto.php
Pay attention to the pushrod clearance through head, very important.
Old Dec 1, 2011 | 07:20 AM
B5Dart69's Avatar
thats wht i was thinking of doin and just sellin this block. how much do u think a 360 magnum bored 30 over and just machined is worth. i have the original rods and crank but there not machined or anything
Old Sep 25, 2012 | 06:20 PM
mydakota340's Avatar
The oil port on the block can be drilled for the heads to get oil but cam not sure.
Old Sep 30, 2012 | 06:10 AM
Gorts 5th's Avatar
Smile
this is how you solve the issue return the stuff before you damage it
hope you got it at a store like summit then you'll have no problems
johnboy
Feb 1, 2012 11:20 AM
Mopar_71
Nov 5, 2011 03:42 AM
cudaracer
Sep 26, 2011 02:43 AM
Tiffany
Sep 22, 2011 11:13 AM
bugy
Feb 1, 2011 08:51 AM
