Trany? may gone out
Old Aug 25, 2008 | 12:29 AM
Originally Posted by richinny
the tranny filter is clogged. don't try to drive it or you'll burn it out like i did. change the filter!
X2 on the filter change, then take it and have a shop flush the whole system. if the filter is clogged then there is still stuff throughout the rest of the system that could clog it again.
Old Aug 25, 2008 | 05:37 PM
challenger's Avatar
Sounds like it is your filter ,,, have a 02 pt and this past winter my trans guy said to change the filter and wala it was just that and with fresh fluid twice its been good to go ever since hope its all that it is for you
Old Aug 25, 2008 | 06:31 PM
Commando's Avatar
I would recommend that you use Royal Purple Oil when refilling the trans. I just put a new filter and Royal Purple in my truck and it runs a lot nicer, but was not too bad before I changed it. Look into it, I will use nothing but that from now on.
Old Aug 26, 2008 | 12:46 AM
i'd check it again during the day then just to be sure.
If you do need a rebuild, instead of regular ATF, I'd use B&M Trick Shift. I use that in my automatic tranny in my jeep and d200 and love it. I used Royal Purple in my manual tranny in my Dakota.
Old Aug 26, 2008 | 04:10 AM
Commando's Avatar
78D200, how do they compare?
Old Aug 26, 2008 | 01:47 PM
I know, its like compairing apples to oranges.
I use B&M fluid in a tranny that needed a rebuild and it actually helped out with improving the shifting and helped it to last a few more months.
A friend of mine tried Royal Purple in his 98 ram 1500 after a simple service and didn't notice any difference with how it shifted and stil had to change it after 25K miles.
I used Royal Purple in my manual tranny and rear axle in my 01 dakota and noticed that it actually rolled better and further down hills in neutral than it did with regular oil.
I guess I'm just saying that my friends I have had better luck with B&M Trick Shift in auto trannys and Royal Purple in manual trannys and axles. Just my .02
Old Aug 26, 2008 | 03:33 PM
ef8340's Avatar
Senior Member
i agree 78 that b&m trick shift fliud is great stuff kinda expensive though but well worth it ,....... its in my dart!
Old Aug 26, 2008 | 05:32 PM
Originally Posted by Doc
Hey ef ... that B&M stuff ? .. is just basically a REdyed type-F fluid !!
well my jeep's tranny loves that REdyed type-F fluid. lol
Old Aug 26, 2008 | 06:27 PM
Commando's Avatar
I have been noticing in my 4 cylinder automatic truck that it shifts later then it did before, so faster acceleration. It also seems to slow down slower, coasts better.
I will try the royal purple in the manual Jeep when I get the 440 out of the back of it, and try it in the Cordoba when the 440 gets into that.
Old Aug 27, 2008 | 04:05 AM
Commando's Avatar
How did the filter look when/if you have pulled it out, was there stuff in it?
Old Aug 27, 2008 | 04:24 PM
challenger's Avatar
hey M528D DOC is right as usuall and the 66 440 motor is 350hp (rated at 4400rpm's) with 10.1:1 comp: and has the same Torque as most @ 480@3200 as were most 440s--- but still if the car is in great shape and with alittle fine tuning it will be a good up and go car in MY book ---- is it the original motor that you no of ?
Old Aug 28, 2008 | 03:33 PM
  #24
challenger's Avatar
I would sure still get it if i was you if its still in fair condition
raycan2
Feb 27, 2014 12:41 PM
Gorts 5th
May 21, 2013 12:29 PM
dazzlesa
Mar 6, 2013 09:14 AM
TwistedWrenches
Apr 11, 2009 03:42 PM
