how do i know if i have a big block k frame
Old 10-27-2010, 01:17 PM
duane66charger's Avatar
Question how do i know if i have a big block k frame
i have a 66 charger with a 318 poly and im not sure if if it would have came stock with a big block k frame or a small block k frame because it is a very wide engine and im thinking the transmission has a big block transmission because it kinda looks like a big block bell housing bolt pattern but im not quite sure what the bolt pattern is supposed too look like.
Old 10-27-2010, 01:58 PM
blue 68 gts's Avatar
All small block
Old 10-28-2010, 12:37 PM
rr69half6bbl's Avatar
You can use the same k frame ,just get big block motor mounts and the rb will drop right in, the trans mounts are the same.
Old 10-29-2010, 12:38 PM
this may sound stupid but what does rb mean?
Old 10-29-2010, 04:09 PM
rb= raised block (413, 426 wedge, 440)
Old 10-30-2010, 02:28 PM
lol, its not a stupid question, i asked the same one when I got into mopars. ohhhhhhh so many yeasr ago. the big blocks, 361, 383, 400. are of course b-big blocks. the 413 and up motors had a longer stroke, maening the piston travels farther from the crank, so the y had to raise the deck height, of the block to accept this extra stroke, thus, rb. Raised block, or raised deck.
Old 10-31-2010, 01:58 PM
Thumbs up
oh ok thanks for the help
Old 11-30-2010, 12:36 PM
condor74's Avatar
All V8 K members are the same. The transmission from your poly 318 will not fit your big block. You will need to get a big block transmission. The transmission mount is the same. There are no such things as stupid questions. We all had to learn some time. Good Luck.
Old 11-30-2010, 12:51 PM
I don't know about your particular car, but there are aftermarket engine brackets to allow V8's to be swapped into 6 cylinder K members, as well
Old 12-01-2010, 05:32 AM
yes, shumakers.com. they make any and all conversion mounts and brkts, youll need for any mope. considering what you have to do to fab up the required parts to do a conversion, theyre relativley affordable.
Old 12-02-2010, 08:34 AM
72Satellite440's Avatar
I got a 440 put into my 72 Satellite with those mounts and it did pop right in -cost me around 200.00
Old 12-02-2010, 01:48 PM
Just call Micheal.. He'll tell you everything you need to know
68Darthawaii
06-07-2017 07:57 AM
bremereric
03-04-2014 03:11 AM
pipdog69
03-13-2012 11:01 PM
68satellite
05-23-2009 05:33 AM
mahd
04-02-2009 09:05 AM
Quick Reply: how do i know if i have a big block k frame
