2 1969 340 motors for sale
I have two 1969 340 motors for sale.
1. 1 season old with aluminum mopar performance heads. 12:1 compression (needs race fuel). Crane cam 590 lift 300 duration. Mopar performance rocker arms. Kieth black pistons and rods. All ARP fasteners. MSD pro billet distr. Milodon oil pan. Melling high volume oil pump. Needs intake carb and water pump to run. motor ran low 12's in a 4 spd 70 Duster. The mnotor is ready to go. $3500. I do have a Holley strip dominator intake and a edelbrock water pump if you need but they are not on the motor.
2. Needs put togeather. Block has just been 30 over. cam bearings are installed. new pistons and rings. 2 cranks forged and steel. Needs rod and main bearings to install. Have all oroginal and new parts to install. Has new Comp cam and lifters. Comes with 2 instakes aluminum and original steel. comes with alot of parts. $1800.00
Location near Fresno, California
340 motors
Sorry it took so long to reply,One of the blocks is a 1968 and the other is a 1969. here is the numbers.#1. 2780930-340-7 11-69 built just needs intake and water pump.#2. 2780930-340-2 6-68 needs assembled.Dave
on
Hi...I looking for factory 340 exhaust manifolds from 1968-70.
Do you have a set for sale?
Thanks
Wilson
email Denny45@sympatico.ca
Thanks
Wilson
