Body work. 1973 Charger
Old Dec 1, 2008 | 02:07 AM
there are suctions cups that you can try using to get most/some of it out.
Old Dec 6, 2008 | 09:24 PM
challenger's Avatar
do what 78 says and buy you a good suction cup puller as you will not get it all out from the back side either and some times you get lucky and most will pop out for you or you will need a good dent puller but i do not suggest a hand puller with a screw as those just make it worst use the weld on type or the suction cup puller , you can also try a body spoon or a body hammer and dollie
Old Dec 10, 2008 | 01:57 AM
BuckNeccid's Avatar
WV, looks like you're from WV? If you're goin to Cincinnati, I bet you pass right by my house (South Point, OH, across the river from Huntington WV) on the way home for visits. You're welcome to stop by and I can show you some of the things I'm doing/have done and maybe give some old time advice.
Old Dec 11, 2008 | 09:38 PM
BuckNeccid's Avatar
Ahhhh I got you confused with the thread starter, thought you were going to school in Cincinnati. Sheeesh... this getting old stuff isn't all it's cracked up to be
rcknrolfender79
Apr 9, 2010 10:47 PM
ef8340
Dec 17, 2008 12:07 AM
Zach8200
Apr 10, 2008 08:14 PM
P0STER0CH1LD
Jan 22, 2008 10:39 PM
