413 to 440 swap
Old 06-11-2011, 04:50 AM
doc ding's Avatar
413 to 440 swap
A customer brought me winnebago with a 413 he forgot to put anti freeze in and broke the block I have a real sweet 440 out of a car to put in it I know you can do anything you put your mind to I have put 350 chevy engines into payloaders already anything is possible but will I have a lot of problems with this instal
Old 06-11-2011, 05:19 AM
6packCuda's Avatar
It should bolt right in. It's the same block.
Old 06-11-2011, 06:19 AM
Well, it will "bolt right in" but a passenger car engine doesn't belong in a motorhome.
First, they need a cam that's compatible with "heavy truck" use, as well as compression ratio.
Are you planning on using the heavy truck heads off the 413? Generally these are easy to recognise by the modified water pump outlets. Generally, these have better valves to put up with more heat.
rrwallace
05-06-2015 03:09 AM
Morrigan_Aria
09-07-2009 12:20 PM
67Polara
09-06-2009 06:35 PM
joel
02-22-2009 06:58 PM
Cardude
05-02-2007 03:57 PM
Quick Reply: 413 to 440 swap
