73 challenger 340 no top end power
Old 06-18-2011, 03:01 PM
j-man's Avatar
have a 73 challenger has a 340 bored 30 over have gone threw engine and had heads done lets say the works. and at idle and low rpm it runs fine but wen i drive it runs fine till about 4000rpm its pops and spudders and has no power ......can anyone tell me what this could be thanks
Old 06-18-2011, 03:05 PM
j-man's Avatar
oh timming is 2 b4 top dead center or tdc
Old 06-18-2011, 05:17 PM
Archer's Avatar
J -
Do you know what your total advance is?
A few random shots:
You might not be getting enough from the dist or vac advance.
Unfortunately too lean an A/F mix or restrictive exhaust can case the same thing. What kind/size of carb do you have?
Silly question, but you don't have a rev limiter on the ignition, do you?
Old 06-18-2011, 06:51 PM
Ignition breaking up
carb way too lean
floating valve springs, caused by several things--weak, wrong install height, lifter adjustment, etc
flat cam lobe
Old 06-18-2011, 10:01 PM
j-man's Avatar
no rev limiter ....and carb is a holley 750 with dual feed lines may need to clean it out cause found some dirt in the rear bowl could be why cause wen i get to 3500 i try to give it about 80% throttle to listen to see if the rear butterflies open but i hear nothing may be problem now to think of it.. and dont know what a total advance is can you tell me more????
Thanks
j-man
Old 06-18-2011, 10:41 PM
Silverick's Avatar
It could be as simple as a bad power valve in that Holley.
http://www.angelfire.com/fl4/pontiac...lleyInfo2.html
Old 06-19-2011, 07:21 AM
Good tech on ignition. http://www.diamondbackengines.com/te.../ignition-101/
Old 06-19-2011, 04:42 PM
Originally Posted by Archer
J Silly question, but you don't have a rev limiter on the ignition, do you?
I've learned that if the ignition box is slighly wired wrong, the effect of this will act as a rev limiter. I would suggest to just make sure all of your wiring is where it is supposed to be.
Brenda Harnisch
02-19-2015 05:00 PM
mrzods13
02-07-2014 12:05 PM
mrzods13
02-07-2014 12:02 PM
scuba
11-04-2012 05:52 PM
ctrain22
07-11-2010 06:32 PM
Quick Reply: 73 challenger 340 no top end power
