What heads are you planning on going with? cast, iron, alum? You can run a dual quad setup with a motor that is built for 3 dual carbs, but a little larger cam would really help out.
As far as the Carter and Edelbrock carbs go, Edelbrock is basically a Carter. take the labels off and you can't really tell them apart. As far as the Carter comp and Edelbrock performer being the same, that I do not know. I would imagine them being very close especially if they are the same CFM. I could be wrong though.
__________________
Tim and Heather
1968 Plymouth Valiant
4.0HO/AW4/NP231/D44-D60f/r(hybrid)/38s on H1s
