Will 360 Magnum bock and heads bolt to my 72 cuda with 904 transmission?
Old 09-21-2011, 11:17 AM
cudaracer's Avatar
I was going to rebuild my 318 cuda, but I got one heck of a great deal on a Magnum 360 short block (crank, pistons, etc.) and even the Magnum 2.02" valved heads. I hear they flow some good numbers.
I am pretty sure the answer is yes to my install question, but I am wondering what issues I will encounter. I think I read that motor mounts needs modification. Any details there? Bolt pattern should be fine to 904, and there is a flywheel with the block, so that covers balancing, right?
Anything else I am missing?
Any cam or build suggestions for a slightly choppy idle?
I have a Holley dual feed 650 for it.
I am using the camquest6 program, and 420hp is coming up pretty easily with those specs.
Amazing.
Glad I did not **** with the 318.
Thanks all.
I will keep you posted on the build.
-cudaracer
Old 09-21-2011, 02:16 PM
Depending on year and type of converter may not be compatible. Hydraulic lock-ups have a different trans input shaft. The bellhousing will need notching for the crank sensor if used.
Old 09-21-2011, 04:40 PM
cudaracer's Avatar
Coverter?
Old 09-21-2011, 04:47 PM
mr340's Avatar
Torque converter. Internal vs. external engine balancing. Older trans-newer block may not work.
Old 09-26-2011, 02:43 AM
cudaracer's Avatar
What budget headers work best for ebody?
Laura Cullen Reynolds
09-10-2019 09:51 AM
norcalitwin26
06-05-2014 02:16 PM
dpmalibu
08-03-2013 06:05 PM
blue 68 gts
05-25-2012 09:10 AM
Red Devil
20
04-18-2011 06:05 PM
Quick Reply: Will 360 Magnum bock and heads bolt to my 72 cuda with 904 transmission?
