440 to 426 Hemi Conversion
Old 09-29-2011, 11:47 AM
Nomadci's Avatar
I'm sure this topic has been covered before but my search found no results. I have a 68 Charger R/T clone and want to replace the 440 with a Hemi (528, 472 or 426). The car is a stock 4 speed. What will it take (besides lots of time and money) to make this conversion? I have power steering, power brakes and it is an A/C car without any of the A/C components. I would like to run A/C if possible. Will a new Mopar 528 fit any differently than a year correct 426?
Old 09-29-2011, 02:06 PM
If I remember, the K member for a 426 is unique. Other than that, 440's over the years had at least two different "balance" situations, but I believe the hemi also might have had a unique flywheel bolt pattern, not sure. In any case, you'll need to research and make sure the flywheel/ torque converter is balanced to the hemi
Old 09-29-2011, 05:00 PM
Actually it would not take a lot of time just a lot of money !!! Since the vehicle was available with the Hemi
Old 09-30-2011, 05:24 AM
62Furious's Avatar
K-member headers and motor mounts are differantthe trans and tork converter will bolt up as long as you have the flywheel Hemi has 8 bolts and 440 has 6 bolts, 440 must be older or internaly ballents
timmie124
05-24-2011 08:08 AM
Mopar En Fuego
04-28-2010 01:48 PM
68 Sat
01-10-2010 03:49 PM
icemancometh
05-01-2008 05:58 PM
BTKBraden
01-05-2007 08:31 AM
Quick Reply: 440 to 426 Hemi Conversion
