70 duster wheel stud replacement
on
It's happened to all of us !! During the restoration of my Duster a mechanic snapped off 3 of the left handed studs on the rear drivers side. I would like to replace all the left handed studs with right before the project is complete. What is the easiest way to get the studs out ? Can it be done on the car ? Thanks, Steve
ya
I did it with mine
you just gotta hit em out
there pressed into place
when putting the new ones back in, i put washers on the side your tightening, and this will press the new ones into place
I did it with mine
on
Duster Studs
Thanks for the info. I had put penetrating oil and tried to knock them out the first time with no luck, thought their might be a trick to it or something. I guess I need a bigger hammer !! Thanks.
on
Thanks guys, got the back studs out. Having trouble getting the front drum off. Car was in storage for 10 yrs. Front drum is rusted with small rust holes around perimeter. Does this also get "hammered" off. Not going to mess with it until I get more info. Thanks
on
Will do. Should have them off tom. Can you still get 70 front drums at any auto store? It's been a while !! Like 20yrs. since the last time I had em off !!
hckrphil
04-09-2017 02:23 PM
