View Single Post
Old 07-31-2007, 08:45 PM   #4 (permalink)
ucfierocharger
USB car drive man
when you take the window out reach down inside the body panel. as far as you can go and make sure it is solid there. The easiest way to check for the rust there is to remove the outer rear quarter, which if you are spending the money its the right wya to do it, but if you dont have the money, you can reach MOST places by hand to check for rust, but that will just give you an idea. you cant actually KNOW without getting the body dipped or without taking off the fender.
ucfierocharger is offline   Reply With Quote
