318-360 torque converter
Old 03-19-2012, 07:32 PM
mebebob's Avatar
if you had a new 318 converted and you needed it for a 360 what do you thing about grinding the weight off the 360 one and welding it on the 318 converter.??
Old 03-19-2012, 08:46 PM
I am not sure but I don't think it is as easy as that said.
Old 03-20-2012, 02:15 PM
mebebob's Avatar
the converter only bolts on one way. so i was thinking the weight is for the motor anyways not the trans. so welding it on is pretty hard to screw up ...
looking for more imput
Old 03-20-2012, 02:27 PM
I've never felt that welding weights on is a good idea. GRAMS as in fractions of grams, make a difference in engine balance.
I'd say buy a B&M or similar aftermarket flexplate which has the necessary balance built in. That way, you can use a "neutral balance" converter, which makes your selection broader, as well as being able to use that converter if you ever change to a different engine balance situation.
I have a factory 360/ 727 in mine, but when I get a stall converter, I've already got a BM flex to go in there.
Old 03-20-2012, 02:53 PM
The make a kit for the 360 converter Comes with the weight and a templet for position / welding
I used the B&M flex plate with my 360 motor
Old 03-20-2012, 03:57 PM
One of my Favorite sayings is "Going a tad bit cheaper is not always better" that being said make sure you have a good nuetral balance convertor and that B&M 360 flex plate.
74cuda
Cuda Specific Discussion
09-08-2017 04:08 PM
67Polara
07-28-2012 01:49 PM
Nomadci
08-23-2010 02:50 AM
smackhonda
05-26-2010 07:17 PM
68 gtx
10-16-2009 03:43 PM
Quick Reply: 318-360 torque converter
