Dodge ram block
Old 06-04-2012, 07:53 PM
Coondog1997's Avatar
Dodge ram block
I have a 1997 dodge ram. Will the 318 intake fit on the 360 block so that i can put the motor in my truck
Old 06-05-2012, 02:10 AM
The intake is bolted to the heads, not the block but as long as both are from a Magnum motor, then yet.
Old 06-05-2012, 07:46 AM
70 Dart Swinger's Avatar
Don't know about new motors but I have a 340 intake and 360 heads on my 318. Most of the parts but the pistons are interchangeable on those 3 motors.
Old 06-05-2012, 12:43 PM
Im starting a project, putting a carb 360 in my 97 ram with efi 5.2 ghas anyone ever done this?
Old 06-05-2012, 12:46 PM
What are the benefits of a 340 intake and 360 heads? I heard you lost compression putting 360 heads on a 318
Old 06-05-2012, 03:55 PM
LA blocks/heads and Magnum blocks/heads are a little different.
If you go with an Edelbrock or Mopar Performance MPFI intake, then it can be done. But you cannot mount the Magnum "dome" style intake to a set of LA cylinder heads due to the angle of the mounting bolts.
PK1 I believe knows how the swap needs to go.
Old 06-05-2012, 04:07 PM
Can i put la 360 heads on a magnum 318?
Old 06-05-2012, 05:38 PM
PK1
PK1's Avatar
There is no difference between the magnum 360 heads and magnum318 heads. They are one in the same.
You can not use the 340 intake with the magnum heads. Magnum heads a vertical mounting thread boss for the intake. The 340 is slanted. Could you fill the 340 bolts holes and redrill? Sure, but Ive never lined up the runners so your on your own there.
La Heads on magnum block? Magnum heads are significantly better for flow and lighter valves with better oiling. LA intake ports are slightly taller but not much. Will work.
But yes you can, to answer your question. You need to change oiling system though. When you price out the re oiling, new rocker gear, studs, etc..and new custom oil thru pushrods you could get a set of new EQ castings and swap your old gear from the 97. They'll support 450hp.
Old 06-05-2012, 05:57 PM
Well im just getting ideas on things. I have the la carb 360 that i am thinking of putting in my 97 ram with 727 trans. Has anyone done this? Or similar?
Old 06-05-2012, 06:43 PM
We put a 87 carb engine into a 92 EFI computer controlled truck. I tried to keep all the wiring as is but it ended up wired old school mopar carbed wiring. Completely removed the auto shutdown relay and kept mostly temp and oil sensors so they would register at the dash gauges. Wired in neutral safety and a new reverse light circuit. A bit of a pain and you'll need a good full wiring diagram with good electrical knowledge but it can be done with lots of patience.
Old 06-05-2012, 06:52 PM
I was thinking of taking the whole ecu wiring out. Maunal speed sensor out all. How much of a pain will this be?
Old 06-05-2012, 07:42 PM
It probably would be easier than what I started to try, knowing that is the plan from the start. I would not do a wholesale chop and cut though, strip all the covering and use a good diagram to save as many circuits as possible. The reverse light circuit was the only one I had to go into the fuse box and add, but I did try and keep all the dash gauges as is. The 92 was confusing at times because some of the column and other wiring came through the firewall to the large plug connectors turned around and went back in. Had a couple of WTF days, but once I sorted through it, it then made sence and was glad I didn't cut too much out at the start.
Old 06-05-2012, 07:48 PM
Im going to put all aftermarket gauges
Old 06-05-2012, 08:37 PM
Dont know about the compression but I got more throttle response going from a 2 brl carb to a 4 barrel carb. The exhaust flows better too. 318 heads are higher velocity and 340/360 heads are higher flow. I just used parts I had laying around cus I had no money to buy eldelbrock stuff.
Old 06-05-2012, 08:43 PM
I would stay with the FI engine btw. They have better economy and are more efficient. You make more power for same gas. Just work the exhaust, port and polish intake and heads, put a bigger throttle body on it, hotter plugs and you will have alot of power after a tune. Way more then you would get carberated and you still get better mpg.
Old 06-06-2012, 02:26 AM
Why do you want to replace the 318 Magnum block with a 360 LA block? the 318 is internally balanced while the 360 is externaly balanced so you will have to get a different TC for the auto (if you keep it).
Why not replace the Magnum 318 with a Magnum 360, replace the PCM and swap on this - http://www.summitracing.com/parts/DCC-5007852/
If you really want a 360 LA motor, why not spend some money on the heads and get this to keep the EFI - http://www.summitracing.com/parts/EDL-28155/
(These are just ideas)
Old 06-06-2012, 03:24 AM
PK1
PK1's Avatar
Your FI 318 with mag heads will make more power than a stock 360 LA.
As suggested above, the M1 intake and a tune with headers will really wake it up. Easily over 50 HP with stock cam. You currently have no power over 4400 rpm due to the intake and tune.
The 318 magnum has more lift on the cam than the 360 and she was detuned from the factory for durability and detonation which was proven to not be necessary. There is alot left in the tune as is.
The nice thing about using the M1, Headers and the tuner is that they all swap over to the 360. So if the 318 gets tired you could stroke it to 390 ( as stated above, already internally balanced set up ) or swap a boneyard 360 and reuse all your already acquired parts.
Old 06-06-2012, 08:29 AM
What is a good transmission to run with the 318 mag
Old 06-06-2012, 08:48 AM
Is your truck 4wd or 2wd? Do you want an automatic or manual?
Automatic - I would go with a well built 47RH. They were found in the 3/4-1 tons
Manual - NV4500 is the only one I would go with. Its a very strong 5spd. There are two different versions; one has a 6.34:1 1st gear ratio and the second has a 5.61:1 1st gear. For a street vehicle, I would go with the second one as it is usually cheaper the first one I decribed as people in the four wheeling community love the higher rear ratio.
Old 06-06-2012, 09:36 AM
So i got a super victor intake, performance throttle body and spacer. What else can be done?
Old 06-06-2012, 10:52 AM
PK1
PK1's Avatar
You are going to modify a super victor for the 318 magnum? Throttle body spacer? For the factory throttle body or you switch to a carb?
t/s1148
04-29-2015 11:09 AM
pipdog69
03-13-2012 11:01 PM
cliffg50
12-17-2009 02:37 PM
mahd
04-02-2009 09:05 AM
ProEmaster
03-01-2007 12:19 PM
Quick Reply: Dodge ram block
