340 oil filter
Old 07-28-2012, 02:59 PM
willysman69's Avatar
340 oil filter
I have a 69 dart with a 340 and just put headers on it.Does it matter which way the filter housing is turned when you bolt it to the block with the big bolt. I have to relocate it somewhere so the headers will fit thanks
Old 07-28-2012, 04:31 PM
Two things I try for is away from heat and, if possible, hanging down so when the filter is removed it holds most of the oil and you don't get a bath.
Old 07-28-2012, 08:47 PM
No it doesn't matter on the 90 degree adapter.
Old 07-28-2012, 10:34 PM
You can also get the proper "standard" filter mount if the headers allow, and use no 90 adapter. I'm pretty sure I eliminated the 90 adapter when I put the 340 in my old 70, and with headers on my 67 Dart, I don't use one there, either. I do have to use a short filter, Wix part no 51068
dart75
04-12-2015 12:55 PM
willysman69
07-31-2012 04:43 PM
retiredpop
10-04-2010 05:36 PM
Demonized
06-23-2010 10:39 AM
dzltd02
10-28-2008 08:25 AM
Quick Reply: 340 oil filter
