Thread: charging system
View Single Post
Old 09-23-2006, 07:39 PM   #4 (permalink)
moparsforlife
Member
can't really think of anything else. you've pretty well covered all your bases. did you check your alternator to make sure its putting out some power? the only thing you can do is to check the charging system circuit with a test light. there has to be a broken wire somewhere if you changed every part of the system and it still doesn't work.i had some problems with some mopars over the years that the battery went dead for no reason. turned out to be the starter believe it or not.
moparsforlife is offline   Reply With Quote
