67 R/T
67 R/T
I'm a new member and I sure could use some help. I am restoring a 67 Coronet R/T, when I purchased the car it had no hood. I found a standard Coronet hood and the nonfunctioning 67 R/T hood scoop. My problem is the exact placement of the scoop. I'm hoping some one out there has an R/T and take the measurement for me. Also I read some where about having to drill larger hole in the hood frame to accommodate the correct mounting hardware. Any help will be greatly appreciated.
Tony, I can't help you with your scoop placement but I'm sure someone on here can help... Welcome to the forum...Be sure to check out the Mopar of the Month contest.......
