1970 RoadRunner fan clutch
Help! Any idea where I can order a fan clutch for a 70 roadrunner 383cid, non thermal? I have ordered several from 3 vendors and each clutch shaft is received is 1/2 " - 3/4" too long. This places the fan blade against the radiator.
non thermal? it wouldnt be a clutch fan if it was non thermal would it?
or would it be centrifugal. |
carl -
Only suggestion if you have to use a clutch fan (and I'm not a fan, no pun intended, but I use flex fans) would be to call or email Moparcity.com. Archer |
