2 Barrel to 4 Barrel
Old 10-31-2008, 11:53 AM
Jarettb's Avatar
I always like a the Holly Dominator however for your application the RPM would not be a bad choice at all.
Old 10-31-2008, 01:18 PM
BuckNeccid's Avatar
You MAY have to get another passing gear linkage rod to get the correct operation of your tranny. I'm not sure enough of the small block to say for sure.
Old 10-31-2008, 04:38 PM
i went with a holley 4160 600 CFM carb on a Weiand Action+ Plus intake. idle to 6800 RPM, if you can find a cam to match it close you'll be golden.
Old 11-03-2008, 04:13 PM
Senior Member
ef8340's Avatar
i like 78's idea with the weiland/cam i'd also get some 85-87 yr 318 heads too while your changin the intake and stuff the one's you want came on the cop cars [diplomat,grand furys, etc,etc] and i think they also came on others these would work well for yours im not exactly sure but i think the last 3 casting no. are 308, you could check with challenger i think he knows a sight on the net that would give you the exact numbers or get the edelbrock aluminum heads
Polara-Lee
06-18-2020 09:41 AM
phish1270
09-23-2009 04:25 AM
THE GOOSE
08-12-2009 04:08 PM
arizonamoparts
07-29-2009 01:30 PM
ken g
05-17-2009 06:16 AM
Quick Reply: 2 Barrel to 4 Barrel
