| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1 (permalink) |
69 Runner
Could use some help! I have 69 Road Runner with 383 4-spd. Car has an aftermarket scatter shield, Lakewood I think. My problem is the starter(s) both mini and stock are hitting the header. It appears that there are two possible mounting holes for the lower starter bolt. When I bought the car the outboard hole was being used and it is also the one I'm trying to use now. My question is, can I rotate the starter inboard to the other hole without any issues? Will the starter still engage. Don't know what size flywheel is in the car. Thanx
#2 (permalink) |
Senior Member
You cannot move the starter!!!
Your only options are do without headers buy a pair that fit properly modify the ones you have How much interferance is there? Can you "dent" a tube or two with a hammer to clear? I haven't kept up, but there ARE modern, compact and aftermarket starters--with permanent magnet fields--that are much smaller than originals. |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| wheel-tire fit issues | bobby68x | A-Body | 1 | 03-13-2008 12:04 PM |
| '69 383 driving us nuts... | Sidedraft | General Discussion | 3 | 11-27-2007 03:03 AM |
| TWIN TURBO 383 | Jeepfreak | New Member Section | 4 | 11-11-2007 10:43 AM |
| Starter ringgear, and bell housing combo problems | sgoffena | General Technical Questions | 1 | 11-09-2007 07:55 PM |
| 383 engine swap Question? | brewster | B-Body | 1 | 05-10-2007 03:58 PM |
