440 engine question!?
Old 01-12-2014, 05:24 PM
  #31
moparted's Avatar
wont work
Old 01-12-2014, 05:26 PM
  #32
old tired rebel's Avatar
Originally Posted by moparted
wont work
Is it because of the tailshaft?
Old 01-12-2014, 05:33 PM
  #33
moparted's Avatar
yes
Old 04-28-2014, 01:23 PM
  #34
moparman76440's Avatar
Unhappy Help??
I have a 1976 D-100 stepside 2 wheel drive with a 76 440 we pulled out of Winnebago motorhome. The motor was refreshened and had a mild street pounder cam put in it. Other than that it is stock internals. It has a 600 cfm Edelbrock 1406 carb on it sitting on a Weiand dual plane intake. The distributor that is in it now is the one that was on the motor when it was in the motorhome. I was wondering if this would be a problem as i havnt gotten the truck even close to where it should be running. It breaks up alot from take off to 2750ish rpms and after that on up it runs better but still not where it should be. Plugs look dry and whiteish in color..Lean yea i know! Stock fuel pump and water pump yet. I still run the electronic box which is silver not the Orange box and the ballast resistor is a 4-prong not the 2 prong. The tranny is a 727 that was on the motorhome, I put 4.10 gears in the 8.75 rear posi I found and that end works great. Just had to shorten the drive shaft and get it balanced. It is the #742 casting btw. Just wondering if ya'll had any input or suggestions on where to look or what im doing wrong? Thanks!!!
Old 04-28-2014, 03:00 PM
  #35
The problem with the motorhome trans is that a lot of them had an emergency brake added to the tail shaft
600 cfm is too small for a 440
Old 04-28-2014, 09:04 PM
  #36
Yes very true however I got lucky and the one i ended up with didnt have one. I figured it was, looking at 750 cfm Demon for it and eliminating the ballast resistor and electronic control box all together...All depends on the $$$ situation and it aint lookin good so we'll see lol!
Old 05-26-2016, 12:50 PM
  #37
jdexter68's Avatar
Old 05-26-2016, 12:52 PM
  #38
jdexter68's Avatar
Carberautor
The stock thermaquad is 850 cfm the 600 is definitely to small
Old 05-26-2016, 08:12 PM
  #39
moparted's Avatar
topic was dead for over2 yrs
Old 05-26-2016, 09:19 PM
  #40
jdexter68's Avatar
Hmmmm. On my phone it says it was posted 2 days ago. That's crazy
Old 05-27-2016, 03:34 AM
  #41
Maybe you phone is a time machine running slow.
SteveRT
10-15-2014 04:24 PM
Younggun
11-15-2012 12:23 PM
timmymacnj
05-20-2010 09:37 AM
carlosg7915
02-20-2010 10:51 AM
ProEmaster
06-06-2007 11:31 AM
Quick Reply: 440 engine question!?
