hemiharv |
07-25-2009 03:56 PM |
'68 Hemi Charger - Hot Coil
I have a '68 Hemi Charger - 4 speed - no options - what would cause the coil to get hot & crack - problem seemed to start when ignition would not shut off - I have replaced balister resistor, voltage regulator, ignition switch & starter relay. When the battery is hooked up - car not running - coil immediatly gets hot. Began by replacing coil, then other parts listed. Nothing has helped. Car still will not always shut off - when key is in off position, it keeps running. Any suggestions or help would be appreciated. Thanks. (When I test the coil with the battery hooked up, it's showing 9 volts and I believe it should be 0.)
