Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > B-Body
Thread Tools Display Modes
Old 01-26-2009, 08:35 AM   #1 (permalink)
Boz
Junior Member
69 Satellite Exhaust Manifolds
I am needing a Left side Big Block HP Manifold for my 69 and was wondering if all HP Manifolds are the same or if I need to look for a certain year and Body? Thanks
Boz is offline   Reply With Quote
Old 01-26-2009, 03:10 PM   #2 (permalink)
challenger
have you just tried ebay to see what they have ?
challenger is offline   Reply With Quote
Old 01-26-2009, 03:19 PM   #3 (permalink)
Polaradude
Polaradude's Avatar
It would depend on ci of the motor.
__________________
Polaradude is offline   Reply With Quote
Old 01-26-2009, 04:05 PM   #4 (permalink)
Boz
Junior Member
It's a 440 had a 383 originally but motor was pulled when I bought it and they only left the pass side in the car.
Old 01-26-2009, 04:21 PM   #5 (permalink)
67 GTX
what ci is your motor?
__________________
1967 Plymouth GTX 440/4-Speed/Dana 60
67 GTX is offline   Reply With Quote
Old 01-26-2009, 04:42 PM   #6 (permalink)
Polaradude
Polaradude's Avatar
Boz, Iam kinda confused, you are looking for a drivers side 383 or 440 exh. manifold ?
__________________
Old 01-26-2009, 06:58 PM   #7 (permalink)
Boz
Junior Member
I thought 383 and 440 used the same manifolds? I have one from the original 383 that was left in the car. I am putting a 440 in it now.
Old 01-26-2009, 07:36 PM   #8 (permalink)
66sportfury
A.K.A bob dodge
66sportfury's Avatar
i think they are the same. i looked in my parts shed and all the HP manifolds look the same. they all dump out in the same spot. but they all could be 383 or 440? for big blocks i have 383s 400s 440s one 413. but im not sure what manifolds came from wich engines
__________________
this just in 16.9 @ 80mph is NOT fast!
66sportfury is offline   Reply With Quote
Old 01-27-2009, 04:34 AM   #9 (permalink)
Polaradude
Polaradude's Avatar
If you have a part # I can give you the other side #
__________________
Old 01-27-2009, 06:29 AM   #10 (permalink)
Boz
Junior Member
I will try to get the numbers off the Pass side one today. Thanks
Old 01-27-2009, 11:52 AM   #11 (permalink)
Boz
Junior Member
2806900 is the numbers one the one I have. Thanks
Old 01-27-2009, 03:31 PM   #12 (permalink)
Polaradude
Polaradude's Avatar
Here are the options for ya.
2806900 exhaust manifold 1967-1969 383 440 HP right
The above is the one you have.
2806974 exhaust manifold 1967 440 HP left
2843953 exhaust manifold 1968-1969 273 318 A-body left
2843992 exhaust manifold 1968-1969 383 440 HP left
Hope this helps.
__________________
Old 02-08-2010, 11:05 AM   #13 (permalink)
Morrigan_Aria
Hell kitten
Morrigan_Aria's Avatar
Talking
Hope this helps.
Polara, do you happen to know the flow rates on the HP manifolds?
Going to have serious trouble installing stock max Wedge exhaust manifolds due to motor location (1.5" further back, so this is a real pain and a lot of cutting) in the 67.
Trying to locate the flow rates for the HP maifolds and also for the MW set....so I can decide whihc to use and if I have to carve up my baby.
TM!
__________________
Building that SOB Max Wedge!
"Since carburetors and axle ratios are designed for maximum power rather than for outstanding economy, good gas mileage cannot reasonably be expected." 1962 Salesman's Guide to the Max Wedge
Morrigan_Aria is offline   Reply With Quote
Old 02-08-2010, 04:47 PM   #14 (permalink)
67 GTX
Quote:
how come?
__________________
Old 02-08-2010, 05:24 PM   #15 (permalink)
Morrigan_Aria
Hell kitten
Quote:
Originally Posted by 67 GTX View Post
how come?
Well, earlier (65 and earlier) B Bodies had the motor 1.5" more forward in the engine compartment than 66 and later cars. By this, I mean, as you face the engine compartment, the engine would be 1.5" closer to you, away from the firewall. Not a problem, I thought, at first, except maybe fan/radiator clearance. I have not verified the placement of the motor in a pre and post 65 myself, but if Schumaker and TTI (whom I spoke with about my exhaust and not the headers) and Accurate Exhaust Products all tell me the same thing, I am pretty sure it's right. After all, this is their living (the last two reproduce MW exhaust systems, among other things).
Well, not even Schumaker in Seattle makes an adapter to do that 1.5" move forward. I asked. I would have to fabricate an add-on plate. Again, non-issue, right? Then, of course, the trans mount would have to be relocated. Getting worse...and then, a new drive line would have to be made. Add this on top of the already semi-custom max wedge exhaust I wanted to run and this portion alone will run me around 2K.
The other alternative? Equally as ugly.
The passenger Max Wedge exhaust manifold makes a tight ram curl, and at the factory 1967 motor location, this will directly impact on....my firewall. Right where it meets my floor pan, right at the passenger's feet. So I would have to cut both my firewall and floorpan and fabricate something to accomodate that manifold, something about 6" and 6". Ouch. And ugly. Right on the floor.
So basically, I have four evils. 1) rearrange everything in the drivetrain 2) cut my car up 3) use other manifolds or 4) use headers. I hate headers for the record.
I spoke with David Hakim (formerly of MP and now of Mancini Racing) and he says to suck it up and buy the TTI headers. Save some cash, save the headache and hassle, increase my HP and my exhaust will be cheaper to have done locally in a Max Wedge-style with the exhaust dumps.
Sigh.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
69 Satellite Exhaust Manifolds? Boz B-Body 2 12-01-2008 02:45 PM
exhaust question thedusterridesagain Street n Strip 13 11-29-2008 06:36 PM
Ram exhaust plymouthrr1985 Dodge Ram 4 10-17-2008 04:16 AM
Exhaust Manifolds or shorty headers J Dog General Technical Questions 2 06-26-2008 08:10 AM
Mopar Supercar manifolds supercarmanifolds Brands News, Concepts, and Rumors 0 12-05-2007 10:24 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
