74 roadrunner small block to big block conversion
I'm taking out the 318 and putting in a 440 in my 74 roadrunner would the 699 oil pan with the motor clear the k frame. I'm planning on putting in schumacker motor mounts. Also will the stock ignition from the 318 work for now until I can afford MSD.
stock ignition meaning the electronics...yes not the dizzy tho. as far as the pan i couldnt tell you. measure. it could depends what it out of.
The electronics is what i was wondering about thanks, i read that if u have a mid sump on ur pan with the motor mounts you'd be fine i was just wondering.
oil pan
200-1123 fits ALL 66-74 B bodies and All big blocks, check it out
http://store.440source.com/Oil-Pans/products/54/ |
do u guys build hot rods or ****** on them wtf get a clue
