8 3/4 Castings
Old 02-07-2011, 07:16 AM
66coronet440's Avatar
Smile 8 3/4 Castings
will a 489 casting fit into a 742/741 casting unit?
________________________
1966 Coronet 440 318 poly
Old 02-07-2011, 07:40 AM
John Van's Avatar
Did you mean: will a 489 center section fit into a 8 3/4 housing that had a 742 center section in it? Yes! any center section will fit into a 8 3/4 housing. If you meant to change parts from a 489 to 742 center sections the answer is no,they use different parts. Hope that helps!
Old 02-09-2011, 07:28 PM
thanks, yes its a complete 489 center section into a 742 housing.
