| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
anyone know how to decode a BB
This is what is on the side of the block 852029-3 RL
#2 (permalink) |
Could there be a 1 infront of the 8 as a first number? If so then it could be: 1852029 that number was used twice once on the 413 from 1959-62 then on the 426 wedge from 1962-65 both are RB's The -3 at the end should indicate the year as 63' which would put your block as a 63' 426 Wedge*.
Interested in selling it? as it would go great in my 64' whose original engine was a 426 with the same casting numbers! *At least according to the info have at hand! I could be wrong!
__________________
64' Plymouth Sport Fury 58' Triumph TR-3A 72' MGB-GT |
#3 (permalink) |
MasterDebater
There are more casting #'s on that block than just those.
#4 (permalink) |
Member
The casting number is seven digits- there are only six there. If as 64Fury theorizes you left off the first '1', or it's not there anymore, that would be a '62-only 413 block, used in trucks & Max Wedges. Look up on the pad near the distributor- there should be more numbers there that can give more info as to what you have.
| Thread Tools | |
| Display Modes | |
