b-body 318 to 440 swap
Old 09-28-2010, 06:34 PM
ocdmoparworker's Avatar
I've been reading up on this and I'm getting mixed reviews. I have a 1969 dodge Charger with a 318 and want to replace it with a 440. Can I use the same k-member and just beef up the torsion bars and suspension out front to make this engine swap? Thx for the help!
Old 09-30-2010, 07:04 AM
Niedhogg's Avatar
Yup, there are motor mounts available to change from a 318 to 440 without changing the crossmember, and changing torsion bars is all you need to do.
Old 09-30-2010, 07:42 AM
old tired rebel's Avatar
Or if you want a more modern suspension check out alterKation
Old 10-04-2010, 04:01 PM
72Satellite440's Avatar
As for the mounts it was EASY when I used http://www.engine-swaps.com/frames/frame_Homepage.html
Was pretty cheap...around 200 bucks.Doing the same in my 72 Satellite and you may need to beef up the rear end , prob has the old tired 8.25 ...Just switched to 8.75 here
72satellite440-Dan
chlngr1970
09-30-2010 08:54 AM
dusterboy89
05-21-2010 10:48 PM
dustin2100
05-12-2010 03:35 PM
robert_farmelo
08-05-2009 06:39 PM
dobaon22s
11-05-2008 01:42 AM
Quick Reply: b-body 318 to 440 swap
