Brake light question
Old Oct 13, 2008 | 02:52 AM
BuckNeccid's Avatar
Sounds like a bad turn signal switch. The brake lights go thru the switch and are passed back and forth when you turn your turn signals on. When they are not on, there is a connection that only turns on the brake lights. Just plug in your front turn signals, and see if they work too. If they do, it could STILL be the switch because of how the wiring is set, but if they don't, then you pretty well know you have a problem in that area, and wires to chase to be sure it's the switch and not the wiring to the switch or after.
Old Oct 14, 2008 | 02:47 AM
BuckNeccid's Avatar
Most likely... From here, what I'd do is put something between the brake light switch and the activator so they would stay on, and then use a test light. Probe to the leads into the turn signal switch to make sure the power goes into your steering column. If it does, then probe the leads coming out of the column and going to the rear. If they have power, then it's somewhere between there and the back. If they dont have power, it's the switch. What I should have said to begin with is you're most likely right, that pretty well limits it to the turn signal switch.
Old Oct 17, 2008 | 12:51 AM
BuckNeccid's Avatar
Glad to hear that Roadrunner. Now people will know when you're gonna stop. They already know it's designed to MOVE
Old Oct 17, 2008 | 12:23 PM
challenger's Avatar
At least now the chebys and ferds will no when you are stoping for them to catch up
70plumchallenger
Aug 11, 2015 08:26 AM
mr.300
Feb 12, 2012 11:33 AM
66FuryBoy
Jul 31, 2011 01:37 PM
jar84203
Dec 25, 2010 04:19 AM
Jason Calogeros
Aug 23, 2009 03:57 AM
