Carb
Old 06-07-2014, 05:00 AM
chuck1934's Avatar
Carb
Any one know how many cfm the carter carbs had on the 440's?
Something I don't understand is I had straight exhaust tips on my 67 R/t and when I drove with the windows open I got exhaust smell in the car.
I then went to turn down tips and the problem went away.
Old 06-07-2014, 10:51 AM
My understanding is Straight tips need to be extended about 4" past the bumper. Turn down can exit at the bumper. AVS carbs were around 650 cfm
Old 06-07-2014, 11:33 AM
chuck1934's Avatar
I used the formula and came up with 550cfm for 440 @ 6000 rpm. I put a edelbrock 1406 600 cfm on runs perfect. I was told to use a 750 cfm. The straight tips ended at the bumper. That was my problem. I was told that bigger than needed wasn't always better on carbs. Thanks!!
Old 06-10-2014, 05:10 PM
moe7404's Avatar
if iam right the1967 R/T 440. didnt have a big carb, like the 68 AVS, the 67 AFB has a air valve over the rear plates, that is the only AFB with that, i think. i have set an AFB float level at 5/16, with good out come, stock is 7/32.
Old 06-11-2014, 08:04 PM
demetri's Avatar
I am not sure that these simple formulas (engine displacement x rpm x volumetric efficiency) are sufficient, as the air flow through the engine is not constant but pulsating. Also, the carburetors may not always have an honest rating. Anyway, I have a mildly built 68 440 (.477 intake lift, larger valves, a bit higher compression) and I have a 750 AFB on it. I also recently installed a vacuum gage. I will be testing the car at WOT and see what the vacuum is in the 4000-5000 range. If it is under 1.0 or 1.5 inches, then I do not need more carburetor. But if it is more than that, bigger carb will help.
My other 440 (which I do not know its internals, but my guess is it has a cam step up or two from the stock 0.425" intake lift) has a 750 (or 850) Q-jet, and seems to like it.
Also, the square bore AVS's were also 750 cfm. But these are expensive, because they were OEM on the 68-70 Chargers & GTX's etc.
Old 10-23-2014, 05:26 AM
naimarrr67's Avatar
Old 10-23-2014, 05:39 AM
moparted's Avatar
ban him
northcoasttip
09-26-2011 11:23 PM
Quick Reply: Carb
