engine noise
hey when i am kinda on it the motor has like a weird rattle raspy sound what could this be ??
How old is your muffler?
its coming from the engine i know it not back near the muffler
Sounds have a funny way of traveling through the frame to make it sound like they are coming from a different area of the vehicle.
What is the motor? |
is it a ticking noise?
its like a choppy rattle noise
If it is coming from the motor, i would start by checking the timing
heat riser valve or rod bearing?
It could be coming from anywhere..
Rod knock. Bent pushrod Something messed up with rockers you may have a type of head gasket that is supposed to tick.. Mufflers Exhaust carb Valves Lifters Timing ECT It can be many things. you need to provide more info though.. My guess is the carb. |
Heat riser. I'd bet on it.
