help on cluster installation
I'm building a dodge charger 1972 I whant to use the original cluster but due to the condition of the wires I'm going to go with a painless sistem.
My quiestion to the experts is if I can feed the original cluster with painless wires.:confused: Thank you guys. |
pas .... I talked to a guy tonite (from an eBay buy - Doug from northern IN) who works on-the-line doing electrical work. There are a TON of guys here that have similiar probs ...and he said that he would like to help. Here is HOPING he will stop by here ... the sooner - the better !
thank you Doc i'll be waiting for his reply
pas .... he was here last nite ..... after getting home from work at 1am ... but had to get up at 6am. So it was a short-nite ...last nite.
I'll be waiting
thank you again |
yes you can just connect it as the manual says so, its very simple with step by step instructions, if you run to any trouble contact their support line they will gladly guide you through it.
ooooops wrong thread
