Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > B-Body
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 08-14-2008, 12:35 PM   #1 (permalink)
71RR08
Member
71RR08's Avatar
help drive shaft trouble!! 71 RR
i just pulled out my 400 with trans out of my RR im putting in a 440 with trans. i measured both trans and the one on the 440 is 6 inchs shorter than the one on the 400. so im wondering if i gotta get a longer drive shaft or get it welded. cause when i put the 440 with trans in, the driveshaft wont reach the trans... what do i do>>??
71RR08 is offline   Reply With Quote
Old 08-14-2008, 02:41 PM   #2 (permalink)
richinny
Senior Member
you need a longer driveshaft.
junk yard or a machine shop can make a new one. the question is how long. you have to measure it with the car on the ground as the space between the two changes when the axle hangs.
richinny is offline   Reply With Quote
Old 08-14-2008, 03:13 PM   #3 (permalink)
71RR08
Member
71RR08's Avatar
ok thanks i just talked to a machine shop and he told me to get the measurements and said that he can do it! THANKS FOR THE HELP!
Old 08-14-2008, 08:36 PM   #4 (permalink)
Doc
MasterDebater
Doc's Avatar
Is that 440 trans a bolt-on DS ?
Doc is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
80 Volare Duster drive train questions 80VDuster General Discussion 3 07-27-2008 12:58 AM
carb trouble 1972newport_sportsman General Technical Questions 2 01-27-2008 03:04 PM
904 trouble slow70duster A-Body 4 06-29-2007 03:55 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
