| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1 (permalink) |
Member
help drive shaft trouble!! 71 RR
i just pulled out my 400 with trans out of my RR im putting in a 440 with trans. i measured both trans and the one on the 440 is 6 inchs shorter than the one on the 400. so im wondering if i gotta get a longer drive shaft or get it welded. cause when i put the 440 with trans in, the driveshaft wont reach the trans... what do i do>>??
#2 (permalink) |
Senior Member
you need a longer driveshaft.
junk yard or a machine shop can make a new one. the question is how long. you have to measure it with the car on the ground as the space between the two changes when the axle hangs. |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 80 Volare Duster drive train questions | 80VDuster | General Discussion | 3 | 07-27-2008 12:58 AM |
| carb trouble | 1972newport_sportsman | General Technical Questions | 2 | 01-27-2008 03:04 PM |
| 904 trouble | slow70duster | A-Body | 4 | 06-29-2007 03:55 PM |
