I'm back again with the poly 318 - still having issues
Old Feb 20, 2008 | 10:11 AM
I wish I could meet you sometime, you have more guts than any young woman I've ever talked to. I'ts awsome that you even try to do this stuff!!
Now, a few things:
Did you check the shaft length of the two distributors? Does the new one actually rotate when you crank the starter?
This IS a "points" (breaker points, pre-71) distributor?
Can you tell if the points are opening and closing?
Do you have a test lamp or meter?
Do this test
Turn the key on, and hook your test lamp or meter from the coil low voltage terninals--one at a time--and the other test lead to ground.
You should get a light or voltage on one side or the other, maybe both if the points are open. (key on)
If you do not get power at the coil terminals, go up to the ceramic coil ballast resistor, and check both terminals of the resistor with your lamp.(key on) You should get power with the key on on both sides of the resistor. If you only have power on one side, the resistor is bad. If you don't have power on EITHER terminal, you have an ignition switch or wiring problem
If you DID get power at one or both coil terminals, here's next:
If you get power on BOTH sides of the coil, that means that the points are open or are not making contact.
Now put your test lamp on the dist. side of the coil, that is, the low voltage terminal on the coil which goes to the distributor
Bump the engine over--easiest way is to short the starter relay on the firewall--and see if the lamp blinks off and on as the engine cranks
If the lamp stays on when cranking, that means that the points are not closing. They could be corroded, not set correctly or the wire to the points may have a break in it.
If the lamp blinks when cranking
and still no spark, then you might have a bad condenser in the distributor, or the coil may be bad
(If you leave the key on for long periods, it can heat up the coil or resistor, and damage or fail them)
On the other hand, if you do this test, that is, lamp on the dist. side of the coil, and crank engine, and the lamp STAYS OUT when cranking, that means that the points are not opening, and probably need adjustment, or that the wiring in the distributor is shorting to ground.
I guess you know how to set the points? I did not used to set them with a feeler gauge, just a dwell meter. You probably want to set them with a feeler, 'till you get the hang of it. With the points on a high spot on the cam, adjust the points to the proper feeler setting. Hell, I don't even remember what that is anymore, maybe .014-.020? Should be in yor book.
Here's a picture I found on the 'net of a 4 banger, showing how the points must be on the "top" of the lobe and fully open to set the gap
http://home.earthlink.net/~goodspeeds/DISTRIB.GIF
The MAIN thing, to get it running, is that they actually open and close.
Here's the long and short of it:
The ignition switch supplys power (when on) through the ballast resistor to the coil. When cranking, the ignition switch ALSO shorts across the ballast resistor to provide a hotter spark for starting.
The current from the battery starts from ground, up through the distributor case, through the closed points, the coil, the resistor/key, and back to the battery.
When the points open, the magnetic field in the coil that was built up because of the current through it collapses. This collapsing field generates voltage which then charges the condenser. In a split second, these two components oscillate their charge back and forth, generating an AC wave. This is what forms the spark. If the condenser is bad, missing, or shorted, no spark. If the points do not open and close, no spark
Old Feb 20, 2008 | 11:12 AM
Oboy!! Now we have troubles
First, I would not switch the vacuum advance, until you sort out what you have. You might just add more problems.
I'm not familiar with Pertronix--can you post a picture or a link?
But here's the deal. There are very FEW if any electronic systems that you can mix and match components.
It sounds to me as if you have two systems?
An aftermarket Pertronix that you installed in a points type distributor?
A "new" distributor that is out of factory OEM vehicle?
If this is true, you need to do one of three things
Either get the thing back to the Pertronix, the way it was, and see if you can get spark,
or convert to the Mopar factory electronic--and I can help you there, and there is info on the net we can find,
or last, re-convert back to your stock points, at least until you get things sorted out.
It SOUNDS to me as if you connected a factory stock (OEM) electronic distributor into your system, and if so, it won't work, and worse, you may have damaged the distributor. What's inside those is a tiny electric coil. Was there any smoke, smell, etc, when you hooked it up?
Is this what you had with the Pertronix?
http://www.vetteclub.org/technicalti...x%20wiring.jpg
Old Feb 20, 2008 | 11:25 AM
Originally Posted by 66coronetgirlie
I think, since the old one works and has the new electronic ign. i'm just going to switch the vacuum advance from the new one to the old one and see what that does.
I connected the black wire to the coil (which worked immediately before I changed the distributor) and the red wire to the little plastic clip that has 2 prongs sticking out of it on the passenger side of the firewall.
a black wire going to the right prong on the clip (towards drivers side) and the other prong had the red distr. wire and a dark blue wire spliced and plugged
.. spliced the red wire into the blue one and into the plug. Do you have any idea what the dark blue wire is? LOL It runs along the firewall with a bunch of other wires to a box on the drivers side
I would not switch the vacuum advance 'til you get this sorted out
You lost me on the wiring. It sounds like black and red come out of the distributor? If so, this sounds like a factory stock (OEM) electronic distributor, and must hook up to the matching box
You are going to have to describe the wiring you have better. Do you have a camera that you can take a digital picture with?
Does the "new" stuff for the newer 318 have an ignition box that looks like this?
http://www.usaimports.co.uk/images/a8661.jpg
Old Feb 20, 2008 | 01:33 PM
That's what I was afraid of---
the new distributor is a Mopar "factory" electronic distributor, and must be used with the external electronic box that I posted earlier. If you get the parts--the box, the dual ballast, etc, you can convert to this, but for now, I'd lay it aside, and either do one of two things:
Either reinstall the old dist. with the Pertronix, or reinstall the points and get that working. The picture of the firewall clears things up
In the picture of your firewall, the white object on the left is the coil ballast resistor, sometimes called the coil resistor or ignition resistor.
Originally it's job was to do this:
When you are trotting down the road, the alternator working correctly, you battery is NOT actually 12V, but rather 13.5-14V
Coils are designed to run with this resistor in circuit in order to drop the coil voltage down from the 14V at charge to more like 10-11V, varies with engine speed, and whether the battery is up, etc.
Now, when starting, the heavy current of the starter motor drags down the battery voltage, say, to 10V, less in winter----
so the coil would not make a good spark at this low voltage. In order to GET a good spark for starting, there's a separate wire from a separate post on the ignition switch that supplies full battery voltage DURING START to the coil, in other words, bypassing the resistor during starting.
This way, you get more battery voltage to the coil during crank.
THAT IS the entire reason that ignition resistors are used
So far as orginal wiring--the orange/red wires seem to be added. I THINK the wire to the right on the ballast is "ignition" which should be hot with key in run. This should connect to the same place--as the right hand side of the regulator. The left side (screw) of the regulator goes directly to the alternator field.
This appears to be the correct hookup for the Pertronix:
http://www.pertronix.com/support/man...itor12vneg.pdf
Here's a site I found with original diagrams:
http://www.mymopar.com/66to71_wiring.htm
and the underhood wiring for your car:
http://www.mymopar.com/downloads/1966/66CoronetB.JPG
I know it might be a little hard to follow, but
Dark blue feeds 12V from the ignition sw (in run) to the regulator, IGN terminal, down at the bottom. From the regulator terminal, the 12V then goes up to the bottom of the resistor
Notice that only one wire is connected there. THIS TERMINAL is where the red wire coming from the Pertronix unit should connect, leaving the original wire intact
Then, the black from the Pertronix will connect to the coil negative--where the points used to connect from the distributor
If I've lost you, don't get discouraged. The fact that you can post pictures helps a lot.
Old Feb 20, 2008 | 01:50 PM
I don't want you to change that until you get it running again. The car should run well, even if the advance does not work or is disconnected. I don't want you adding even more possibilities for added problems 'til you get it sorted out
Here's a pic I drew up, kinda showing the original wiring, and how the Pertronix fits in. It's laid out like your firewall, but I cannot tell if the two connections on the resistor are still correct. It does not matter if they are switched left to right. I think the wiring on the right side of your resistor goes to the coil, I'm not sure
Old Feb 21, 2008 | 09:46 PM
Hi, kiddo
I assume you've set the timing?
How does it run, the same as you started this problem?
What I'd hoped was to get you back to a starting point. When you replace "stuff" with unknown "stuff" many times it simply adds to the problem.
later, if for some reason you decide to install the OEM Mopar electronic system, I can help you with that some. In some ways, it's more work to install, but uses "stock" parts and is probably more reliable than the Pertronix
Assuming it still runs as before, stalling, this sound more like a carb/ vaccum/ fuel problem, rather than ignition.
Even if the distributor vaccum advance fails (leaks) or even if the centrifugal (mechanical) advance sticks, the engine should still idle good.
So----
a few things to think over.
First, did this stalling problem just happen, or did you change something and then it developed?
Assuming it "just happened" here's a few thought:
There is some remote chance that the timing chain slipped, but if it is running "on the marks" so far as timing, then that is not the case.
What do you have for vacuum accessories? You can check easily by just following hoses. Power brakes? PCV valve? Cruise control?
Any of these, you can check by simply pulling the hoses and plugging them, even with your finger.
One common problem, is that the carb may have picked up some dirt, and one idle jet may be plugged. Can you adjust the idle speed?
Can you adjust the idle screws, and do they have any effect?
Old Feb 22, 2008 | 07:15 PM
64fury's Avatar
This almost sound identical to the way a friends Chev 350 died, turned out he some how grounded all the spark plugs. We finally figured that out after tearing the entrie eletrical system down.
Before you start pulling more stuff of and changing things out, make your self a spark tester (link below) to see if the dizzy is actually sending a spark out, check all 8 wires (one at a time, don't mix em up), then start checking the connections, following the wiring from the dizzy backwards, the coil, any grounds etc! It sounds like the problem is electrical, the spark tester is a fast and esay way to see if you have a spark without trying to fire the engine up. I don't have much experience with the electric on these car yet, but the British make the worlds worst automotive electrical systems, so if I can figure those out you should be able to get this one running again!
http://www.mgexperience.net/article/spark-tester.html
Old Feb 25, 2008 | 05:40 AM
64fury's Avatar
If the wiring is so messed up, it may be cheaper in the long run to get a Painless kit!
http://store.summitracing.com/partde...5&autoview=sku
55dodgec3b
May 13, 2012 04:29 AM
Beerstop
Jan 5, 2011 06:02 PM
OHD
Apr 7, 2010 09:27 AM
DUST360
Sep 19, 2009 04:20 AM
green_machine
Feb 6, 2009 02:59 PM
