Stripped Intake manifold at thermostat housing?
Spent the better half of Sunday afternoon replacing my recored radiator, hoses, thermostat...etc. When I went to replace the housing for the thermostat I noticed one bolt felt stripped (just bought the car). Anyway the obvious occurred when I started it. Water and antifreeze everywhere. Any suggestions on what to do for this problem?
http://co103w.col103.mail.live.com/a...AF87879F8F9E0| |
what is the motor and vehicle?
If the threads are in the intake, then you might be able to use a heli-coil to fix it... Or upgrade the intake:D |
it is a 318 original motor.
Did the bolt break, or were the threads stripped? You may just be able to re-tap it, without seeing it I can't assess the the damage.
