Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > B-Body
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 09-20-2007, 06:56 AM   #1 (permalink)
ICENROAD
charger 383 4sp
ICENROAD's Avatar
TRANSMISSION PROBLEM
Hello all,I have a question about my transmission and that I hope someone can answer.
I have a 1972 charger that has a 383 with a 4 speed transmission.
I took the transmission out to be rebuilt by taking out the 4 bolts hooked to the bellhousing and left the bell housing and clutch preasure plate and throwout alone .
i inspected the throwout to make sure that was not the noise was fine took trans to shop was needle bering inside broke had the hole trans overhalled.
Got the trans back the clutch was new in 2000 with only 2500 miles since put in so reinstalled throwout put trans in car.
Now trans acts like Im not pushing clutch in all the way (it grinds going in gear ),ajusted clutch dont help so I pulled thinking the throwout.
whent back in again still same problem was wondering if ajustment on linkage for shifter could be the problem .
any info will be really helpfull
THANK YOU, DEAD IN THE WATER
ICENROAD is offline   Reply With Quote
Old 10-11-2007, 05:59 PM   #2 (permalink)
power ram man
Junior Member
how are your syncros? and then how are your slave and master cylinders
__________________
power ram man
power ram man is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
2001 Neon Idle Problem Newf General Technical Questions 0 06-22-2007 09:44 PM
Electrical problem with 2000 Intrepid TCPMeta General Technical Questions 0 03-28-2007 04:27 AM
Carburetor problem fundadtn Dodge Ram 0 01-17-2007 01:44 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
