Viper Roadrunner
Viper implant
Wondering if anyone put a new Hemi or viper Engine in a mopar 60s or 70s. If u did is like to hear from u please
Mel@moparmel.com
Mel@moparmel.com
Working on it at the moment, you need to cut the trans tunnel, and modify the torsion bar / transmission cross member to fit the T-56, you need a tubular K-member.. The K-member requires the motor mounts to be moved forward four inches..
You can no longer fit a Mopar Steering box, you have to go non powered rack and pinion..
Anything after that, drive shaft, rear end, fuel, electrical, isn't a big deal..
You can still use the torsion bars, and have a comfortable spot for your shifter..
Check out my thread in member projects, 1972 Charger from Windsor Ontario.
