1966 Monaco 4 BBl conversion ( Camshaft ?)
Old 02-10-2017, 05:24 PM
KJoeZ61's Avatar
I have a stock 4 door 66 Monaco that I installed a 4 BBl intake and carb on several years ago but didn't swap the camshaft. The engine runs great however its got a few oil leaks and the freeze out plugs need to be replaced so I'm pulling the motor this spring because its time to address these issues. Could anyone recommend a good camshaft & lifter kit to put in? Also planning on replacing the timing chain as well.
The cars exterior and interior were fully redone a few years ago, its a solid car and it deserves these improvements. Also it was converted to duel exhaust as well.
Joe
Old 02-10-2017, 06:08 PM
To keep it a nice driver... I would say nothing over an advertised 270* Duration.
i'm Going to guess this is a 383C.I. ?????????
Welcome to the site... I use to own an 67 2-Door... Nice cars..
Old 02-10-2017, 06:56 PM
KJoeZ61's Avatar
Yes its a 383
Old 02-11-2017, 06:18 AM
Comp Cams. # 21-215-4 268H , this should liven up the 383 with 218 @ .050. and .454 lift, get the kit with springs and timing set and you good to go.
Old 02-11-2017, 01:22 PM
KJoeZ61's Avatar
stupid question, would I use the stock springs or replace them?
Old 02-11-2017, 03:01 PM
Replace.
http://www.compcams.com/Company/CC/c...?csid=699&sb=2
Polara_68
06-11-2017 08:13 PM
labradorian70
10-08-2014 12:21 PM
mrzods13
02-22-2014 08:37 AM
KJoeZ61
07-24-2011 09:59 PM
dodgeaspenrookie
05-10-2008 12:03 AM
Quick Reply: 1966 Monaco 4 BBl conversion ( Camshaft ?)
