68 Fury 2 disc brakes
Junior Member
on
I have a 68 Fury 2 ex highway patrol car and it is equipped with front disc brakes. I am trying to find some replacement brake pads and I was wondering if anyone knew if they still make them and where I may find some. Dr. Mopar in Texas informed me that the 65-68 c-body brake parts were interchangable but I'm still struggling.
Thanks
Rob
Thanks
Rob
Guest
Posts: n/a
i did a quick search and found no listing for calipers for that model. i had disk brakes on a 68 chrysler 300. the parts might be the same. i'll throw in that when i replaced the master cylinder that the correct master for my car was a DRUM brake master with the equal sized compartments. i believe it was the first year chrysler offered disks on that model.
Junior Member
on
master cylinder
Junior Member
on
calipers
I just took the caliper apart and found out that the rubber boot around the piston is leaking fluid and I was woundering if you, or anybody else, new a quick fix to this problem. I know you said you have disc brakes on your 68 300 and the parts should be the same. Have you had to replace the calipers or have them rebuilt????
